Premium Polycarbonate Window Well Covers in Utah
* Expert installation add-on available at checkout
$0.00$0.00
Polycarbonate Window Well In Stock and Ready for Installation
Our brand new Premium Polycarbonate window well cover is not just an upgrade – it’s a completely new design. By adding an edge-to-edge aluminum frame we engineered it for unparalleled strength and durability in its class. Our Premium Polycarbonate covers are available in all the same sizes as our standard frameless polycarbonate covers and both styles are in stock and ready to purchase! Key features include:
- Stronger: The outer aluminum frame makes our Premium Polycarbonate covers stronger and easier to walk on compared to frameless polycarbonate window well covers.
- Better Looking: The cover’s wraparound frame also hides the lip of your window well for a more finished look.
- Crystal Clear: All of our polycarbonate is scratch resistant and won’t crack or turn yellow.
- Holds More Weight: With the robust integrated frame our Premium Polycarbonate covers can now hold up to 300 lbs.
- Longer Warranty: Better engineering means a longer-lasting cover. With our Premium Polycarbonate covers we’ve extended our full structural warranty to 10 years.
Our order process is simple
- 1Measure your window wells that need covers
- 2Select the closest size from our in-stock inventory for each and add to your cart
- 3Choose pick up at our Lindon headquarters or delivery within our delivery service area
- 4Finalize and pay for your order
- 5Simple online checkout and immediate order confirmation affirm your order has been received and your products are ready to go
- 6Pick up or receive delivery
- 7Install and enjoy peace of mind for your family, a more finished appearance for your house!
- 8You’re happy, we’re happy
Measuring Guide
Measure how far your well extends away from your foundation, this is the depth from the house. Now measure your window well where it meets your foundation from side to side, this will give you the width.
